C class sunroof closes too high
Old Oct 25, 2005 | 12:44 PM
powerharp's Avatar
Default C class sunroof closes too high
The glass sunroof on my 98 C230 closes about 1/8" higher than the roofline and I can't see how to adjust it. I have no idea of the cause, but there is significant additional wind noise caused by this.
Help!
Old Oct 25, 2005 | 03:23 PM
C280 wizard's Avatar
Default RE: C class sunroof closes too high
Sunroof adhustments should be left to a expert, I've been there. Try some Silicone and White Lithium grease on all the joints and runner perhaps it needs a "lube" job. I just bought a 79 450SLC and the rear part of the sunroof wouldn't close tight, so I got out the old trusty Silicone spray and white lithium grease and a little here and there and it come all the way down. I "lube" mine at least twice a year. On the plastic pieces use Silicone and on the metal i.e. runners use the white lithium, last a lot longer than WD40. I use the Silicone on the plastic as a mechanic advised me to never use anything but Silicone on plastic. Make sure you spray inside the roof where the sunroof disappears as best you can.
rbr115
Apr 3, 2011 08:23 AM
V XII
Jun 9, 2006 09:24 PM
ROADRAGE
Dec 31, 2005 03:13 AM
tx380sl
May 23, 2005 12:12 AM
Furby
Nov 24, 2003 12:16 AM
