beeping with key in igniton etc
Old Aug 11, 2006 | 08:50 PM
tankerpilot's Avatar
Default beeping with key in igniton etc
1998 c280. When I put the key in the ignition and turn it to position 1, beeping starts and doesn't stop. When I turn it to position 2 the beeping stops but then all intrument lighting etc is on. If after starting the car I turn it off, the beeping starts again and does not stop until I take the key out. Why does it beep in postion 1 and why does it beep when the car is turned off? I've had the car for a little over a year, and I don't think it was always this way. Thanks for any help.
Old Aug 12, 2006 | 12:36 AM
PolishPat's Avatar
Default RE: beeping with key in igniton etc
usually the seatbelt sensor causes the beeping in position 1. Buckle up first, and then start, see if u have a difference!!!
Old Aug 12, 2006 | 06:32 AM
Sorry, I meant to mention this occurs with the seat belt connected. No other faults are indicated, just the beeping. If it is the seatbelt sensor, where is it and is it a DYI item or do I need MB maintenance? Thanks for the help.
Old Aug 12, 2006 | 04:15 PM
PolishPat's Avatar
the seat belt sensor is usually located right inside of the buckle and Its def a MB Maintenance, but before we jump to any conclusions, lets see if anyone else can diagnose this problem
jbeaulau
Mar 1, 2014 07:58 PM
MBenzAMG
Nov 8, 2013 03:50 PM
dan7
Aug 13, 2012 10:06 PM
brantchastain
Nov 30, 2010 01:25 PM
tzito
Apr 6, 2008 11:15 PM
