Air Conditioning Whistles
Old Jul 15, 2007 | 12:08 PM
photog3740's Avatar
Default Air Conditioning Whistles
I have a 1997 C280. The air conditioning whistles (an up and down whistle). It doesn't matter which fan speed I have it set to. It's a very distracting and annoying sound. I recently replaced the cabin filter about a month ago, but this noise just started. I took out the cabin filter and put it back in, but this had no effect. Could the unit be low on freon? What should the pressure read on the low side?
Any help is GREATLY appreciated.
Old Jul 15, 2007 | 03:56 PM
C280owner's Avatar
Default RE: Air Conditioning Whistles
Hey there,
I haev a 94 C280 and sometime got the same sound (a vuuuuuu....) only during windshield defrost in the winter. However regarding teh AC I have an issue, maybe you could help me. I need to recharge the AC with R134a refrigerant and have got a refill kit from Autozone with a gauge. i found the low pressure port just under the engine and has a black cap on it.i tried to match it with the hsoe but would not fit. any suggestions on how to proceed and refill it ? thanks
Old Jul 16, 2007 | 07:51 PM
photog3740's Avatar
Are you sure you had the low side? If the pipe on the car was to big it is the high side. Also, the hose on your Autozone kit will be hard to push on because the ac system is under pressure.
jab
Jun 11, 2005 02:25 AM
memkaz
Apr 10, 2005 02:32 AM
tim
Aug 19, 2004 11:48 AM
pseverin
Jul 8, 2004 03:25 AM
lulu
Jun 27, 2004 12:38 PM
