Air conditioner blew hot air during traffic jam
Old Aug 28, 2006 | 12:53 PM
cckcheng's Avatar
Default Air conditioner blew hot air during traffic jam
Hi everbody
I found that the a/c of my C240 started blowing hot air after about 10 min traffic jam in the city traffic. As soon as the traffic moved, it resumed blowing freezing cool air. Anyone had simialr experience before?
Thanks.
Christopher
Old Sep 6, 2006 | 04:28 PM
gpagdilao's Avatar
Default RE: Air conditioner blew hot air during traffic jam
The compressor for your AC needs to be serviced or replaced. It sounds like the diafram is worn out.
Old Sep 7, 2006 | 12:11 PM
RockSolid's Avatar
the a/c of my C240 started blowing hot air... As soon as the traffic moved, it resumed blowing freezing cool air.
If your compressor is working well, when it works, but shuts off from time to time, it's most likely the evaporative temperature sensor starting to go bad. ( Much less expensive fix.) This is a fairly common problem on W202's : I don't know about W203's like you C240.
Good luck.
Old Sep 7, 2006 | 03:12 PM
CarMan's Avatar
My wifes 02 C240 was doing the exact same thing this week. Turned out it needed freon. It was like 15 bucks.
Old Sep 7, 2006 | 09:52 PM
RockSolid's Avatar
My advice is don't assume the worst, ie, compressor, condenser, evaporator, untill you've checked the less expensive items.
SheIsMe
May 28, 2017 08:25 PM
Marshman UK
Jul 29, 2011 04:40 AM
HondaWhisperer
Jun 17, 2011 10:47 AM
caligal
Jun 4, 2011 11:24 AM
galad
Mar 22, 2010 04:34 AM
