ac problems?
Old 07-13-2005 | 12:46 AM
pitar's Avatar
Default ac problems?
hello guys,
this is my first post, hope to join in little more from now on.
I have a problem with my 2000 c 230. AC was working fine last summer and since I didnt use the car much this year I just had it recharged today but I realized it is still blowing warm air. AC clutch is not kicking in at all. I was wondering if the ac relay could be the problem and where is it located/is it hard to replace it? Just wanted to see what are my options before i take the car to dealership? any suggestions?
thanks!
Old 07-13-2005 | 01:57 AM
mikdade's Avatar
Default RE: ac problems?
was it blowing warm air when you took it in for svc? why did the tech let you leave w/o it working?
Assuming that your system is similar to most others: there isn't a relay, the a/c clutch receives on / off input from the computer for driver demand. The system is protected from damage by sensors (refrigerant & evap temp and refrigerant pressure).
If you paid the tech take it back, if you did not then stay away.
Old 07-13-2005 | 03:45 AM
sleepwalker's Avatar
203?
maybe evaporator or pressure sensor.
that EC led is on?
Old 07-14-2005 | 01:00 PM
paulstefano's Avatar
I can't help you with your problem, but I have an even crazier problem.
Currently the A/C works in 3 vents. For some reason, however when running the far left vent blows hot air, while the rest blow cold.
Anybody have any thoughts? I wouldn't think what I'm describing would even be possible, if I didn't witness it myself.
thanks,
paul
Old 07-14-2005 | 08:32 PM
C280 wizard's Avatar
Perhaps the flap door isn't opening on that vent? Some cars have separate flaps doors for heat and AC for the corner vents and one for the middle vent. These are usually vacumn operated. but on a Mercedes who knows?
Old 07-14-2005 | 08:36 PM
hot air
not warm air?
do actuations of the flaps individualy to see if it works. (by using the a/c pushbutton unit).
can be: flap, water valve or lack of freon.
Old 07-14-2005 | 10:47 PM
How do you do that? Which buttons. If you can help I would appreciate it, I have a 1995 C220.
thanks,
paul
Old 07-15-2005 | 03:52 AM
the instructions has been posted here a few times.
please try the search function.
  #9
Old 07-15-2005 | 05:10 AM
SL600_Cruzin's Avatar
check out this thread. There's a lot of good info there ----> https://mercedesforum.com/m_18063/mp..._/tm.htm#18928
Cheers
  #10
Old 07-16-2005 | 01:44 PM
pitar's Avatar
ORIGINAL: sleepwalker
203?
that EC led is on?
EC is suppose to be on when AC is on or not? It works when I put it on.
Quick Reply: ac problems?
