99 C280 - Upgraded tires and speedometer
Old Aug 23, 2006 | 08:57 PM
Bvanderweide's Avatar
Default 99 C280 - Upgraded tires and speedometer
I am planning on replacing my stock 15" rims and tires with 16". This may be kind of a silly question, but will the change in tire size affect the accuracy of my speedometer or odometer? My guess is that it will have a negligable affect, but just curious if anyone has had experience with this issue.
Thanks!
Old Aug 26, 2006 | 01:07 PM
RockSolid's Avatar
Default RE: 99 C280 - Upgraded tires and speedometer
It depends. If you intend to use a lower profile tire to keep the overall diameter of the wheel and tire the same, the speedo won't know the difference. However, to get the exact dimentions the same is probably not possible. The closer you can get the better off you'll be. BTW, as long as your makeing the change, the '99 C280 can accept 17" wheels w/o a problem. If it were me, that's what I'd consider. Check out this wheel size calculator
mveron
Sep 11, 2009 12:29 PM
mveron
Sep 8, 2009 04:16 PM
mb3800
Nov 28, 2008 02:39 PM
lopezcc
May 26, 2005 05:23 PM
ransford1994
Dec 28, 2004 12:48 PM
