500class
Old Mar 11, 2006 | 09:04 PM
wfhart's Avatar
Default 500class
Vehicle was in water and cats were damaged. became very hot. now that the cats are changed the cylinders on the entire right bank are not firing,its running on the left bank only. both dist caps were changed injectirs swapped, compression at 170 on all cylinders and it has spark but the injectors are not puling on one side only? is there a ressitor for the harness somewhere/ Thanks Bill
Old Mar 11, 2006 | 10:59 PM
sleepwalker's Avatar
Default RE: 500class
the problem is that there is no ignition on the right bank?
injection is fine? it sprays fuel?
any fault code?
