2001 C320 Radio problem, help...
Old 01-01-2006 | 02:46 AM
JamesE's Avatar
Default 2001 C320 Radio problem, help...
Hello everyone, I just bought the above and have no sound coming from the radio. Let me elaborate. The display seems to be functioning fine, changing am-fm, etc but there is no volume what so ever. I push cd and it says no cd changer when there is and it seems to be intact. I put a cd in and tried it but same result. Its also says no phone when I push the phone button also.
Now here's the strange part, I have the orignal window sticker and someone has taken a pen and marked out the $2100 MB phone option??? Did they take out the phone and disable the radio? Its not asking for a code, the display indicates all is fine (I guess)... Thanks in advance for any help !!!
Old 01-01-2006 | 03:27 AM
sleepwalker's Avatar
Default RE: 2001 E320 Radio problem, help...
if your system uses D2B and the telephone module is faulty/removed... then there will be no communication with the CD changer, no phone and no sound either.
Old 01-01-2006 | 10:49 AM
JamesE's Avatar
OK, thanks. that gives me a place to start. How do I find this out? Where's this piece located, I'll look for it. If I had to buy a replacement, about how much would it be? I'm going to call the dealer back tomorrow, he should back this, (I hope). Thanks alot
Old 01-01-2006 | 12:09 PM
JamesE's Avatar
I messed up, its a C320. If that makes a difference.
ORIGINAL: sleepwalker
Old 01-01-2006 | 01:08 PM
james, please tell me your VIN.
i need all the data from your car by knowing the VIN.
tomorrow i'll advise you about it.
Old 01-01-2006 | 06:21 PM
JamesE's Avatar
Here you go, WDBRF64J91F103975 thanks so much!!!!
Old 01-02-2006 | 01:16 AM
well, your car is not fitted with cel phone and cd changer from factory.
you got sound system and e-call.
you can install tel and cd changer but it will be a set.
Old 01-02-2006 | 09:07 PM
JamesE's Avatar
Thanks for leg work sleepwalker. Its does have a genuine MB 6 disc inside the glove box, so that must have been installed after I guess. The dealer said they'll take care of it, spoke with them this morning.
  #9
Old 01-02-2006 | 11:24 PM
that's right. it only needs repair since they install original retrofit equipment.
[IMG]local://upfiles/1/8F98C740488E4E3083FDC4AC38B72553.jpg[/IMG]
  #10
Old 01-03-2006 | 12:22 AM
JamesE's Avatar
You're awesome man!!
