2001 c240 won't start, electrical issues
Old Jun 26, 2011 | 06:42 AM
Mercnovice's Avatar
Default 2001 c240 won't start, electrical issues
2001 c240 ignition issue. Started after charging battery while battery cables still connected to vehicle. Vehicle will start and run fine until I turn off the vehicle and remove the key. When I re-insert key, car doesn't recognize key and won't allow me to unlock ignition until I disconnect and reconnect battery. If left over night, battery is completely drained. when battery disconnected and recharged the car starts ok. If I disconnect and reconnect battery car starts fine. Also, if I remove and reinsert ignition fuse the car will start. I hear a relay click when removing and re-installing ignition fuse, which makes me think a relay contact might be sticking and seizing until the battery is drained. I don't see any electrical items being powered when the key is removed, so I'm not certain of what is draining the battery. Any idea what is causing this?
Mercnovice
Jun 19, 2011 05:55 AM
chango650
May 9, 2008 07:03 PM
tabourj
Nov 26, 2006 04:37 AM
jfe105
Sep 8, 2006 01:58 PM
