2000 C230 ESP LIGHT
2000 C230 ESP LIGHT
I HAVE BEEN HAVING A PROBLEM WITH THE ESP LIGHT BEING ON . I READ ON ONE OF THE FORUMS THAT SOMETIMES THE RELAY ON THE RELAY BOARD BREAKS LOSE ON THE CIRCUT BOARD BUT I HAVE CHECKED THE RELAY BOARD AND NO LUCK. WE ARE LOOKING INTO REPLACING ONE OF THE WIREING HARNESSES BUT NOT SURE WHICH ONE YET. HAVE BEEN TOLD THE CONNECTORS MAY BE BAD. IT WOULD APPEAR THAT IT HAS MY KOMPRESSOR AND MY CRUISE SHUT DOWN. ANYONE GOT ANY IDEAS? THANKS RON
RE: 2000 C230 ESP LIGHT
This is a common problem, and relates to the "brake light switch" It's a $15-$20 US part ($20+ from an MB dealer) and will take you about 10 minutes and a screwdriver to fix. Follow this link for detailed pictures/explanation on how to do it.
http://www.benzworld.org/forums/foru...=1166641&posts
PHIDELT, I FINALY GOT OUT THERE YESTERDAY AND GOT THE SWITCH OUT. RAN A COUPLE OF TESTS ON IT AND FOUND IT TO BE DEFECTIVE. CONTACTS WERE UP TO 8 TO 13 OHMS. TOOK IT APART AND USED SOME CONTACT CLEANER. RE CHECKED AND GOT IT DOWN TO .3 OHMS AND REPLACED. TOOK CARE OF THE ESP LIGHT, THE CRUISE CONTRL AND THE KOMRESSOR. I REALLY WANT TO THANK YOU FOR THE LINK. A SPECIAL THANKS TO TIM FOR HIS INSTRUCTS ON HOW TO DO THE JOB. ( GREAT LAYOUT). AGAIN THANKS TO ALL FOR YOUR HELP. RON
Link is no longer working - ESP BAS issue and brakes have mind of their own!
I brought my car to my mechanic, he hooked it up to the computer (the light was not on at the time) and he could not find anything.
I would like to try and replace the brake light switch to see if this fixes the problem, however, when I click on the link above it does not work.
Has it moved?
I have a 2000 C230 Kompressor (100 K miles) and the first thing that happens is the brakes start to apply by themselves, then the BAS ESP light comes on. When I turn the car off for a while, turn it back on, the BAS ESP light is off.
Has it moved?
Has it moved?
Will be interesting to see what the Mercedes Doctor has to say.
It turns out that the fault was the yaw sensor for the ESP. The bad - very bad - news was that it had to be sourced from Germany, would take almost two weeks to be fixed, and would cost $1400. And the car is undriveable until then.
The sputtering engine problem was unrelated - just bad plugs.
Kikoap
07-30-2012 02:50 PM
