1997-C280 Bad Windshield Wiper Motor
Yeah its not the very bottom part but the long plastic piece, you can pry up on the bottom of it and it will then pop up or depending on the wiper you will slide the plastic piece down so it pops out of the top then pull it off, then you can pull off the plastic piece then youll see a metal rod or shock thing you want to lube that. Its best to put the wiper partially up pointing toward the top left of the windshield cause thats when the rod is fully extended so you can lube the whole length of the rod... Or piston i should call it...THIS LUBING OF THE PISTON WILL HELP IF YOU HAVE THE WIPER ARM STOPPING ON THE WINDSHIELD WHILE ITS WORKING. IF YOU GET NO MOVEMENT OF THE WIPER ARM AT ALL THEN MAYBE THE SCREW CAME LOOSE ON THE MOTOR AND ALL YOULL NEED TO DO IS TIGHTEN IT AND THEN YOULL BE OK. OR THE SWITCH ITSELF GOES BAD. USUALLY WILL OPERATE INTERMITANTLY AND YOU CAN GET IT TO WORK BY PLAYING WITH THE SWITCH.
gus_carrero
Jul 16, 2007 10:22 AM
