1996 C280 top left heater hoses
Old Apr 4, 2010 | 04:34 PM
mr.darwin's Avatar
Default 1996 C280 top left heater hoses
Does anyone have DIY instructions for changing the 2 top left heater hoses and this part: 2028321115 - Heater Pipe; Assembly Through Left Side Firewall to Heater Core.
The hoses are very hard to reach. Thanks!
1996 C280
Old Sep 11, 2013 | 02:54 AM
tonydanza's Avatar
Default same question !
Hi Mr Darwin
Did you find the DIY ? I know this thead is 3 years old....but I do have to do the same job and it is like the part is impossible to reach
Any help ?
Thanks.
Old Sep 13, 2013 | 11:34 PM
mr.darwin's Avatar
It is an easy fix. I don't know the technical terms, but let's call the broken piece 'the connector'. This piece mounts in the 'firewall' and connects the heater hose on each side. if you look at that part of the firewall, you will see how it is attached on each side. take those screws out and you can lift the firewal up a few inches, that allows you to replace the connector piece. hope this makes sense and works for you.
briang
Oct 1, 2007 08:06 AM
aztntrunner
Jul 29, 2007 06:59 PM
out of spec
Mar 16, 2007 12:23 PM
JEFF D
Jul 26, 2006 01:23 PM
kalanikaau
Jul 8, 2006 10:04 PM
