1996 220c Crank Position Sensor
I need to locate were the CPS is located on this car. My car was running good, until I had to replace the passenger side tire, after that the car won't start, I was advised that the Crank Position Sensor, is not propertly secured, that it might be loose. Can you HELP locate were this part is located under the hood? Thanks
cjshade
8
11-28-2007 08:38 PM
