1995 c280 key ignition
Please I need help, just got this 1995 C280 few weeks ago. Suddenly the fuel and the heat gauges stop working. In the second day I tried to start the car but the key in not turning in the ignition. Appreciate your help.
RE: 1995 c280 key ignition
if there is a tension on the steering wheel lock, the ignition switch is difficult to turn. try moving the steering wheel a bit.
if you play with the ignition switch, the cluster lights comes on? fuses ok?
Zaboss,
Hope your 'key' issue is already resloved. I had the same problem in my 94 C280 which left me stranded at a gas station. The key just won't turn and if you do a search, you'll know it can be costly(in my case, I had to pay almost $1500 CAD). the consolation prize is a new key from MB.
Good luck.
KC
Good luck.
KC
Myran
12-06-2018 03:17 PM
71280sl
10-04-2010 11:38 AM
brantchastain
10-02-2010 06:17 PM
