1995 C220
Old Jun 28, 2005 | 11:24 PM
edpayne's Avatar
Default 1995 C220
I have had some fuel sensor problems in the past, it feels as if my newest problem might be related and I would like to know if anybody has had the same problem. The idle has always been rough and it seems too low, but the latest is a problem that has stopped me from driving it, today. The engne won't run at a constant speed the car if you bear down on the pedal the car abruptly goes fast then slow, up and down....
Anyone had this happen to them?
Old Jun 29, 2005 | 02:06 AM
SL600_Cruzin's Avatar
Default RE: 1995 C220
Please list a bit more about the car's history.
Has it had a tune-up in a while ? Fuel Filter, Air Filter Replaced & when ?
There's several things that could be causing the problem you're describing.
When you say "The idle has always been rough and it seems too low, but the latest is a problem that has stopped me from driving it, today." do you mean that it started running rough then died completely and won't start again ?
If you give us a bit more feedback we may be able to help.
TJ
Old Aug 25, 2015 | 09:02 PM
Wallyworld's Avatar
I had an unsteady idle that went away when I had the mass air flow sensor replaced. Hope this helps.
Uneek
Aug 31, 2005 08:00 AM
jimb96
May 4, 2005 01:31 AM
kirr45
Mar 6, 2004 10:10 PM
joeyc220
Feb 20, 2004 11:48 PM
LiftedDisco
Jan 21, 2004 04:06 PM
