'02 C240 won't crank, won't shift out of park
'02 C240 75k won't crank, won't shift out of park. no power at fuse 55 or 52 when key is turned to crank position. turned key to run and put 12 volts to fuse 52, car starts and runs fine but still won't come out of park. anybody have any more ideas?
Trans control module could be filled up with trans fluid. Also the rear sam/fuse box are common issue on those cars. Keys also are a problem. maybe you just have a bad relay? try swapping relays around.
I swapped key with spare, same results-- how do I check the trans. module can I take it off and inspect--what is "rear sam/ fuse" what do I check, which relays do I swap around
the rear sam is in the trunk on the left side of the panel. there is an access panel. the sam is attached to the fuse box.
when I say swap relays I mean swap ones that are the same.
Sorry for long delay getting back to you but it's been cold in Connecticut. I did swap all of the relays around in the engine compartment fuse bay and now it comes out of park normally. I don't know if this had anything to do with the relays? So now, my only problem is that the engine won't crank unless I put power to fuse 52. Once I do that the car starts and can be driven fairly normally. Do you have any ideas on what I would try now? Thanks.
STAR TekInfo
Concord did you ever get you car fixed? I'm having the same problems as you had. Car drove fine last year. The battery went dead over the winter. I just put a new battery in it and it won't start now. I have to run a wire to the fuse to get it started but I can't get the car out of park now. How did you get it out of park? Any help would be nice or tips to getting out of park. Lol if I can do that ill just put a starter button switch from the battery and fuse box
Hey Bub, I did get my car started normally. It turned out to be a relay either in the k or the s position of the front fuse box. I noticed that the symptoms changed when I switched these two relays with each other so I bought two new ones on line for $5 and now the car starts and runs fine! If you have a C240 or similar car, you can easily get it out of park by opening the cup holder and popping out the small change holder and reaching in with a screw driver and pushing down on the white tab which will unlock the gear shifter. This is described in your owner's manual as well. I think I dodged a huge bullet at the dealerships! Let me know how you make out.
I don't have a owners manual that y I'm online looking stuff up. Well I went out and worked on the car a little bit. I got it to come out of park. Switched the relays around still no start. Now I get a p0600 code that says serial communication link malfunction so I'm thinking the ECM/ECU is shot. Thanks for the info on the shifter
