'02 C240 won't crank, won't shift out of park
Old Apr 5, 2014 | 09:44 PM
  #11
Bub48161's Avatar
Well I got the car up and running and starting with the key. It comes out of gear and drives fine. I took all the plugs from the ECM and Sam/fuse box and cleaned all the connections and fuse slots. Everything was corroded and not getting a good conection. There was water in the box that holds the ECM so I made a few holes so the water won't stand in there and splash around. The windshield wipers work now too. So all and all seems to be good now. Thanks everyone that helped. So if you have a no crank no start check the ECM.
Old Jun 16, 2020 | 02:09 AM
  #12
WO NG's Avatar
Default check the 20A transmission relay
My one have the same problem..turn out is a transmission relay ..i swap it with the horn relay.and it work perfect.
mercedesman232
Feb 22, 2014 05:51 PM
so clean1
Sep 2, 2008 07:27 AM
Ezbiker
Feb 23, 2008 10:35 AM
bpham
May 25, 2007 08:00 AM
lhemmer
Oct 6, 2006 12:56 PM
