Mercedes Benz Forum Help & Suggestion Center Have a suggestion to better Mercedes Forum? Need help with a feature on Mercedes Forum? Post here.
Repair Costs
Old Yesterday | 12:32 PM
njustin1's Avatar
Default Repair Costs
Hello all, here is the report I got from a repair shop with a quote of $14,200 to fix 2012 E350. Thoughts? Upon inspection of vehicle confirmed misfire present. Performed SCAN of vehicle and found codes active for cylinder 1 and 2 misfires . Swapped coil and plugs with cylinder 3 and found misfire to remain on cylinder 1 and 2. Performed a running compression test and found to be ok. Checked lived data of fuel system and found the fuel pressure to drop after key was turned off indicating leaking fuel injectors. Performed resistance check of injectors 2 and 3 and found to be the same at 214k ohms. During resistance check found oil contamination present within the engine harness and ME control unit. Recommend replacing engine harness, ME control unit and oil contaminated components.
Fleshtik
Sep 13, 2025 01:37 PM
100tinka
Jul 3, 2024 10:23 AM
PelicanParts.com
Aug 20, 2013 07:02 PM
PelicanParts.com
Jun 11, 2013 05:30 PM
AMGMercedes
May 14, 2008 01:00 PM
