A190 2004 Fault codes
These are the codes given on the merc
P0110-002
B1 7 intake air temperature sensor
Intake air temperature sensor
Overvoltage : open circuit in wiring
Would be great to have some advise or solution on this?
P0110-002
Transmission control fault codes PO700-PO787.
P0700
Transmission Control System Malfunction
P0701
Transmission Control System Range/Performance
P0702
Transmission Control System Electrical
P0703
Torque Converter/Brake Switch B Circuit Malfunction
P0704
Clutch Switch Input Circuit Malfunction
P0705
Transmission Range Sensor Circuit Malfunction PRNDL Input
P0706
Transmission Range Sensor Circuit Range/Performance
P0707
Transmission Range Sensor Circuit Low Input
P0708
Transmission Range Sensor Circuit High Input
P0709
Transmission Range Sensor Circuit Intermittent
P0710
Transmission Fluid Temperature Sensor Circuit Malfunction
P0711
Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712
Transmission Fluid Temperature Sensor Circuit Low Input
P0713
Transmission Fluid Temperature Sensor Circuit High Input
P0714
Transmission Fluid Temperature Sensor Circuit Intermittent
P0715
Input/Turbine Speed Sensor Circuit Malfunction
P0716
Input/Turbine Speed Sensor Circuit Range/Performance
P0717
Input/Turbine Speed Sensor Circuit No Signal
P0718
Input/Turbine Speed Sensor Circuit Intermittent
P0719
Torque Converter/Brake Switch B Circuit Low
P0720
Output Speed Sensor Circuit Malfunction
P0721
Output Speed Sensor Circuit Range/Performance
P0722
Output Speed Sensor Circuit No Signal
P0723
Output Speed Sensor Circuit Intermittent
P0724
Torque Converter/Brake Switch B Circuit High
P0725
Engine Speed Input Circuit Malfunction
P0726
Engine Speed Input Circuit Range/Performance
P0727
Engine Speed Input Circuit No Signal
P0728
Engine Speed Input Circuit Intermittent
P0730
Incorrect Gear Ratio
P0731
Gear 1 Incorrect Ratio
P0732
Gear 2 Incorrect Ratio
P0733
Gear 3 Incorrect Ratio
P0734
Gear 4 Incorrect Ratio
P0735
Gear 5 Incorrect Ratio
P0736
Reverse Incorrect Ratio
P0740
Torque Converter Clutch Circuit Malfunction
P0741
Torque Converter Clutch Circuit Performance or Stuck Off
P0742
Torque Converter Clutch Circuit Stuck On
P0743
Torque Converter Clutch Circuit Electrical
P0744
Torque Converter Clutch Circuit Intermittent
P0745
Pressure Control Solenoid Malfunction
P0746
Pressure Control Solenoid Performance or Stuck Off
P0747
Pressure Control Solenoid Stuck On
P0748
Pressure Control Solenoid Electrical
P0749
Pressure Control Solenoid Intermittent
P0750
Shift Solenoid A Malfunction
P0751
Shift Solenoid A Performance or Stuck Off
P0752
Shift Solenoid A Stuck On
P0753
Shift Solenoid A Electrical
P0754
Shift Solenoid A Intermittent
P0755
Shift Solenoid B Malfunction
P0756
Shift Solenoid B Performance or Stuck Off
P0757
Shift Solenoid B Stuck On
P0758
Shift Solenoid B Electrical
P0759
Shift Solenoid B Intermittent
P0760
Shift Solenoid C Malfunction
P0761
Shift Solenoid C Performance or Stuck Off
P0762
Shift Solenoid C Stuck On
P0763
Shift Solenoid C Electrical
P0764
Shift Solenoid C Intermittent
P0765
Shift Solenoid D Malfunction
P0766
Shift Solenoid D Performance or Stuck Off
P0767
Shift Solenoid D Stuck On
P0768
Shift Solenoid D Electrical
P0769
Shift Solenoid D Intermittent
P0770
Shift Solenoid E Malfunction
P0771
Shift Solenoid E Performance or Stuck Off
P0772
Shift Solenoid E Stuck On
P0773
Shift Solenoid E Electrical
P0774
Shift Solenoid E Intermittent
P0775
Pressure Control Solenoid "B"
P0776
Pressure Control Solenoid "B" Performance or Stuck off
P0777
Pressure Control Solenoid "B" Stuck On
P0778
Pressure Control Solenoid "B" Electrical
P0779
Pressure Control Solenoid "B" Intermittent
P0780
Shift Malfunction
P0781
1-2 Shift Malfunction
P0782
2-3 Shift Malfunction
P0783
3-4 Shift Malfunction
P0784
4-5 Shift Malfunction
P0785
Shift/Timing Solenoid Malfunction
P0786
Shift/Timing Solenoid Range/Performance
P0787
Shift/Timing Solenoid low
P0700
P0701
P0702
P0703
P0704
P0705
P0706
P0707
P0708
P0709
P0710
P0711
P0712
P0713
P0714
P0715
P0716
P0717
P0718
P0719
P0720
P0721
P0722
P0723
P0724
P0725
P0726
P0727
P0728
P0730
P0731
P0732
P0733
P0734
P0735
P0736
P0740
P0741
P0742
P0743
P0744
P0745
P0746
P0747
P0748
P0749
P0750
P0751
P0752
P0753
P0754
P0755
P0756
P0757
P0758
P0759
P0760
P0761
P0762
P0763
P0764
P0765
P0766
P0767
P0768
P0769
P0770
P0771
P0772
P0773
P0774
P0775
P0776
P0777
P0778
P0779
P0780
Shift Malfunction
P0781
P0782
P0783
P0784
P0785
P0786
P0787
SLK 230 1998 compressor, S799FGU.
Can you please give me an answer to the following, a few days ago I got a spanner symbol and -169 on my total mileage window,
next day it was 170, today 171.
Also how can I reset an ABS light on the dash.
Three wires to boot lid catch, where do they originate from
There must be a clever Merc man out there somewhere
regards
Brian
regards
Brian
htech4739
Mar 15, 2018 07:11 PM
