B class 2014 1.8 Fails to start in hot temperatures
Old Sep 8, 2023 | 01:45 PM
pete349's Avatar
Angry B class 2014 1.8 Fails to start in hot temperatures
Good Evening
My 2014 B Class 1.8 has an issue when the temperature is hot (over 25 degrees) my car wont start! I have had the issue for several years only happening in the summer. the first time it happened the investigation resulted the the battery wasn't good enough, a year later I have the same problem. replacing the battery again hasn't cured the problem.
I have found the only way to start the car is to disconnect the battery for 10 minutes and it seems to reset and enable me to start the car. Although it does not cure the issue.
any advise is greatly received
Many thanks
Pete
Old Nov 1, 2023 | 05:30 AM
sanap's Avatar
Originally Posted by pete349
Good Evening
Many thanks
Pete
Hi Pete,
I have the same issue on B200, 2005 model. Engine cranks , but not starting in a hot weather. Have you found the cause of your problem yet?
Regards, Jack
evomind
Aug 31, 2023 11:34 AM
sefe
Mercedes A Class
Nov 2, 2020 01:29 PM
GOMES
Dec 19, 2006 01:44 PM
ivanpztorres
Jul 11, 2006 12:16 PM
