K1 Motorsport HRE | BRABUS | Lorinser | RennTech | KLEEMANN | Carlsson | H&R | Bilstein | AMG | iceLink Pro | OEM and more.
Key/program
Old Jun 17, 2009 | 05:29 PM
wiltonhenry's Avatar
Default Key/program
I purchased a spare key for my 2001 s500/the dealer said they can only program a key purchased from them for...300.00 any suggestions.....wilt
Old Jun 17, 2009 | 06:52 PM
silverstartech's Avatar
CONNECT A BATTERY CHARGER!!!! put the key in the ignition and turn to position 2. (2 clicks. go slow till the dash lights up) DO NOT TRY TO START!!!!!. You will see the red led on the key go on and stay on. You will see the light go out anywhere from 1 min to 6 hours later. Then you may start the car.
Old Jun 18, 2009 | 09:25 PM
Default key program
How many amps on charger/can this be done without the charger/will the remote open the doors also
Old Jun 19, 2009 | 01:07 PM
the new remote should open the doors since it is ordered by VIN. the charger need to be connected because the programming can not be interupted. (key in ignition) if it is the key will be no good. you can put a charger at 5-15 amps. This should be sufficent. like i said before, sometimes it takes only 5 min to program. It all depends on how the car feels that day
Old Jun 19, 2009 | 07:59 PM
Default Key
Gotcha/thanks
ferg32
Feb 19, 2009 10:09 PM
alghawas
Aug 11, 2008 08:56 AM
jacksrbet
Mar 9, 2008 05:14 PM
assad
Jun 11, 2006 05:10 AM
xquisite
Jan 4, 2005 02:12 PM
