Interior What have you done to the inside of your ride? Talk about it here.
interior color change...
Old 07-22-2005 | 10:07 PM
kevinrea's Avatar
Default interior color change...
hi guys,
i just bought a 1990 560sec.., and i do not really care for the intereior color of blue.
have any of you changed or had the interior color changed in your benz ?
from this:
to this:
i am wanting to change it to gray or the beige mercedes color..
any thoughts ?
thanks,
kevin
kevinrea@adelphia.net
Old 07-23-2005 | 03:45 AM
kevinrea's Avatar
Default RE: interior color change...
i should have said, that i was planning on chaning the color by dying the leather, not replacing it..
kevin
Old 07-08-2006 | 02:32 AM
marknute's Avatar
why would you want to change that color, it looks nice
i have a 1990 560SEL with gray interior and the sun has changed the color of some panels... now i wish i had a darker color...
keep in mind that your blue won't do what my gray did.[:@]
Old 09-21-2006 | 11:56 PM
Charles Munn's Avatar
About 2 months ago i bought a 1982 300D T. The palimono drivers seat was not fastened properly and there was a hole in the backrest. I needed a subsitute while I figure out a way to repair the original, so I bought a decent blue driver's seat out of a wreaked 1982 SD for $25.00. I then thoroughly cleaned and prepped it as per the directions, then sprayed on 15 or so thin coats of palimino vinyl paint ..... I'm glad that seat's only a substitute, because it's already beginning to rub off in certain areas.... I haven't found any paint on my clothing, but if I keep it in much longer, it's obvious that I'll have to re-touch it.
Best wishes,
charlie
saa7ir
04-04-2011 11:19 PM
stuartjoyce
07-28-2008 04:29 PM
rooms
03-17-2008 12:34 PM
mespe
08-22-2007 11:27 AM
