interior color change...
hi guys,
i just bought a 1990 560sec.., and i do not really care for the intereior color of blue. have any of you changed or had the interior color changed in your benz ? from this: http://www.ourkitty.com/images/mercedes/14.jpg to this: http://www.ourkitty.com/images/mercedes/beige.jpg i am wanting to change it to gray or the beige mercedes color.. any thoughts ? thanks, kevin kevinrea@adelphia.net |
RE: interior color change...
i should have said, that i was planning on chaning the color by dying the leather, not replacing it..
kevin |
why would you want to change that color, it looks nice:D
i have a 1990 560SEL with gray interior and the sun has changed the color of some panels... now i wish i had a darker color... keep in mind that your blue won't do what my gray did.[:@] |
About 2 months ago i bought a 1982 300D T. The palimono drivers seat was not fastened properly and there was a hole in the backrest. I needed a subsitute while I figure out a way to repair the original, so I bought a decent blue driver's seat out of a wreaked 1982 SD for $25.00. I then thoroughly cleaned and prepped it as per the directions, then sprayed on 15 or so thin coats of palimino vinyl paint ..... I'm glad that seat's only a substitute, because it's already beginning to rub off in certain areas.... I haven't found any paint on my clothing, but if I keep it in much longer, it's obvious that I'll have to re-touch it.
Best wishes, charlie |
