Which wire is hot?
Which wire is hot?
Hey guys,
I'm working with the garage door opener module (Homelink) located inside the rear view mirror of a 2000 E320. One wire is brown the other is white with a blue stripe. Which one is the positive and which one is the ground. I talked with my local dealer and they do not have a wire diagram for inside the mirror.
Any help is appreciated. Thanks
RE: Which wire is hot?
I am wiring the module into another car (different make and model)so I needed to know which wireis positive and which is the ground. I assume it takes 12 volts as the wires run to the main mirror plug which connects into the car's wiring system.
Thanks in advance for any assistance.
anacortesjim
10-17-2012 07:07 AM
wawago
03-07-2006 05:27 AM
