will not crank after accident
was told by somebody that mercedes have a fuse near battery that will blow when there is an accident
check the battery connector.
one member found out that they have painted the battery terminals as well.
I don't know specifically about yours, but many manufacturers turn the fuel pump off when the car gets bumped. It does this so gas isn't fed into a fire, if there is one. It's a switch that has to be manually turned back on. You may want to check into this. Info may be in your owner's manual.
ar1217
Mar 1, 2011 06:21 AM
dongjun42
Jan 6, 2011 09:03 PM
al_corbett
Nov 27, 2005 04:07 PM
bonxk8
Mar 29, 2004 03:21 AM
