wheel wobble c class
Old May 6, 2006 | 09:19 AM
diamond geezer's Avatar
Default wheel wobble c class
my 1994 c220 auto is suffering from a wheel wobble felt through the steering wheel from about 55 mph,i have replaced the 2 front tyres and had all wheels balanced and even had the suspension components checked by a garage and was told they were o.k,their is some play in the front wheel bearings but i was told by the mechanic that this is normal,does anyone have any other ideas what the problem might be as i dont know what to do next.
Old May 6, 2006 | 09:26 AM
sleepwalker's Avatar
Default RE: wheel wobble c class
it's still the wheel.
have you tried swapping front to rear?
Old May 6, 2006 | 09:41 AM
i will give it a try as i am out of options...thanks for the advice
Old May 9, 2006 | 07:36 PM
infn8kw3st's Avatar
bent rims??
Old May 10, 2006 | 08:22 AM
purchased brand new set of replicas 3 weeks ago hoping it would cure it but problem persists....VERY ANNOYING!
Old May 10, 2006 | 08:32 AM
replicas...means wheels with tires?
you should have done the swap test first.
Old May 15, 2006 | 01:14 PM
sorry for confusion..replicas means 4 new merc style alloy rims(not genuine merc but replica)...tried wheel swap but still the same
Old May 16, 2006 | 04:51 AM
jnolte's Avatar
could be steering damper or blown control arm bushings
Old May 16, 2006 | 07:55 AM
  #9
did not think of steering damper..will take a look..thanks for advice
Old May 16, 2006 | 01:25 PM
  #10
keithe's Avatar
Had similar problem with replicas on my CLK430. Turned out I had two problems. One, one of the wheels was out of round so much that could not be propely balanced. A good tire installer can measure trueness of wheel to diagnose that problem. That is problem with some replica wheel mfg...quality control is not always there. Other was since I had gone up to 19", low profile tires when sitting overnight get flat spot and need to heat up to get rid of wobble.
