what is scheduled for 60k miles ?
Old Nov 14, 2005 | 11:13 PM
WANTED_560SEC's Avatar
Default what is scheduled for 60k miles ?
hello every one i was wondering what maintenance is scheduled for 60k miles and then what is the next maintenance after that? for a 560sec ?
Old Nov 15, 2005 | 01:38 AM
SL600_Cruzin's Avatar
Default RE: what is scheduled for 60k miles ?
Not sure what year 560 SEC you're talking about, but for a 1991 here's the list.
Maintenance: Normal Service 60,000 MILES ( or 96,000 KM )
Adjust
Drive Belt
Parking Brake System
Check
Brakes and Traction Control
Clean brake discs and pads, road test system. Adjust parking brake.
Clutch, M/T
Check operation.
Heating and Air Conditioning
Check operation and Freon charge.
Clean
Antenna Mast
Tape Player
Tape Deck Head.
Inspect
Accessories and Optional Equipment
Battery
Clutch Disc, M/T
Clutch Fluid - Hydraulic Brake Fluid, SAE Ji 703, DOT-4
Convertible Top - Check level of hydraulic system, check operation of locking lug.
Coolant Ethylene Glycol Coolant; Mix with water to desired freeze protection.
Check degree of antifreeze protection.
Drive/Propeller Shaft Drive Shaft Flex Discs.
Fluid - Differential --- Gear Oil, API Service GL-5 or Special Lubricant for Limited Dfferentials; Mercedes-Benz Part No. 000 583 09 04. 4MATIC models, also check front differential.
Fluid - Transfer Case -- DEXRON-II Automatic Transmission Fluid -- 4MATIC models.
Fuel Supply Line -- Check fuel tank, lines.
Level Controller -- Special Lubrication Fluid -- Level Control.
Power Steering Fluid
Inspect condition of lines and hoses.
Seat Belt Systems Steering
Inspect linkage (Front Axle, Steering Linkage And Boots), check freeplay, retorque mounting bolts.
Wiper and Washer Systems
Lubricate
Body and Frame
Hinge, Hood
Sunroof Track
Throttle Cable/Linkage with Special Lubricant Fluid - Mercedes-Benz Part No. 000 989 91 03 10 at least twice a year.
Replace
Air Filter Element
Air Injection Filter
If equipped. Brake Fluid
Hydraulic Brake Fluid, SAE J1703, DOT-4 Cabin Air Filter (as equipped)
Fluid - A/T or M/T
Fluid Filter - A/T
Fuel Filter
Oil..... (At least once a year if year-round multigrade oil is used. Otherwise, at least every spring and fall.)
Oil Filter, Engine
Oxygen Sensor
Spark Plug
Wiper Blade
Rotate Wheels
Hope this helps
Old Nov 15, 2005 | 01:41 AM
Here's the next maintenance after that one.
Maintenance: Normal Service 67,500 MILES (or 108,000KM)
Lubricate
Throttle Cable/Linkage - Special Lubricant Fluid - Mercedes-Benz Part No. 000 989 91 03 10 at least twice a year.
Replace
Oil - (At least once a year If year-round multigrade oil is used. Otherwise, at least every spring and fall.)
Oil Filter, Engine
Again ... I hope this helps
Old Nov 15, 2005 | 02:35 AM
its for a 1989 560sec.... that is great information....... thanks alot... i am looking to buy a car with 72800 miles. is there any maintenance at this mileage or close to ?
Old Nov 15, 2005 | 02:51 AM
For the 1989 560 SEC here goes:
Maintenance: Normal Service 75,000 MILES (or 120000 KM)
Adjust
Drive Belt
Check
Brakes and Traction Control - Clean brake discs and pads, road test system. Adjust parking brake except 140 chassis.
Clutch, M/T - Check operation.
Heating and Air Conditioning - Check operation and Freon charge.
Clean
Antenna Mast
Tape Player - Tape Deck Head.
Inspect
Battery
Brake Fluid - Hydraulic Brake Fluid, SAE J1 703, DOT-4
Clutch Fluid - Hydraulic Brake Fluid, SAE J1 703. DOT-4
Coolant - Ethylene Glycol Coolant; Mix with water to desired freeze protection. - Check degree of antifreeze protection.
Fluid-A/T - DEXR ON-Il (R) Automatic Transmission Fluid
Fluid – Differential - Gear Oil, API Service GL-5 or Special Lubricant for Limited Differentials; Mercedes-Benz Part No. 000 583 09 04. 4MA TIC models, also check front differential.
Fluid - M/T - Gear Lubricant, Special
Fluid - Transfer Case - DEXR ON-Il (R) Automatic Transmission Fluid 4MA TIC models.
Fuel Supply Line - Check fuel tank, lines.
Level Controller - Special Lubrication Fluid. Level Control.
Power Steering Fluid - Power Steering Fluid - Inspect condition of lines and hoses.
Seat Belt Systems
Spark Plugs - Replace as necessary.
Steering - Inspect linkage (Front Axle, Steering Linkage And Boots), check freeplay, retorque mounting bolts.
Lubricate
Body and Frame
Hinge, Hood . Sunroof Track .
Throttle Cable/Linkage - Special Lubricant Fluid - Mercedes-Benz Part No. 000 989 91 03 10 - At least twice a year.
Replace
Cabin Air Filter - as equipped
Oil - At least once a year if year-round multigrade oil is used Otherwise, at least every spring and fall
Oil Filter, Engine
Wiper Blade
Rotate
Wheels
Good luck with it !
Cheers
Old Nov 15, 2005 | 03:32 AM
wow that is great. how often do i have to maintane this car it sounds like every 5k miles ? and also how much is all of this maintenance ?
Old Nov 15, 2005 | 03:49 AM
ORIGINAL: WANTED_560SEC
Looks like every 7,500 MILES
Depends upon where you take it. Ask around for a good european auto shop in your area. They'll be cheaper than the dealer. But watch out, there's some really good ones and there's some really bad ones. Get referals if possible, then go with your gut feeling.
Cheers
Boxsterboy
Sep 3, 2012 10:25 AM
benzdude5
May 14, 2010 11:15 PM
lisalisa83
Oct 30, 2006 02:22 PM
billc112
Aug 6, 2006 07:57 PM
ComcastC230
May 12, 2006 06:44 PM
