What kind of pump is this?
Old Feb 29, 2004 | 12:38 PM
sasquatch's Avatar
Default What kind of pump is this?
I have a '91 300se. Yesterday I went to start it and I was immediately greeted with a meat grinder noise from the Block. I said a short prayer, and looked to find that a pump on the passenger (USA) side of the engine compartment just above the alternator had finally died. Problem is I don't know exactly what the pump is for, but I think it may be a vacuum pump.
Can anybody identify this pump for me - so I can order a new one?
Here's a photo:
<edited><editID>sasquatch</editID><editDate>38046.4718981481</editDate></edited>
Old Mar 1, 2004 | 02:37 PM
dave190e's Avatar
i reckon its either going to be power steering or aircon, what pipes are conected to it and where do they goto.</P><edited><editID>dave190e</editID><editDate>38047.5261111111</editDate></edited>
Old Mar 5, 2004 | 01:11 AM
SANDDOG's Avatar
Will if it was your power steering pump, there is no way you could steer. Unless you really are a sasquatch. Anyhow its your air pump, you can drive the car, the engine needs to get rid of crank case gases and some pressure the air pump help's out. Go to, The partbin.com very easy to replace two hose in/out. good luck
Sep 19, 2006 03:12 AM
Ashlee
Nov 12, 2005 03:38 AM
tgmiller77
Sep 25, 2005 12:06 AM
Jake_S
May 4, 2005 07:10 PM
MSG300E
Feb 6, 2005 03:55 PM
