?? Water pump, bearing
I just got this E320 1994 mercedes. My son is working on the fan and belt and radiator. He has found some small pcs in the water pump, I guess where the fan fits into. I assume there is a bearing there, is that correct?? If any9one can help it would be great thks
Hello and welcome to the forum! Take a look at the link below - it may help you troubleshoot. Please let us know if you have any other questions or if we can assist with any part needs in the future.
https://www.pelicanparts.com/techart...Water_Pump.htm
I dont think its the waterpump, there on the dirivers side of the pump and hole, that had a bearing in it. The bearing came apart. Not sure what that is called. It might b where the fan gets attached to if the fan went there I would need to replace that bearing. Dont know the name of the bearing or the area. It is just to the side of the waterpump. I would of thought that the fan would get attached to the pump. help pls
