Vito´s instrument cluster broken ?
Old Jan 17, 2005 | 02:34 PM
timer's Avatar
Default Vito´s instrument cluster broken ?
After battery change all warning lights start flashing 2-3 sec periods.
If the fuel level sensor is disconnected everything works ok (not fuel gauge of course)
Sensor value measured: 75ohm = ok
Signal route to MCU (inside panel) cheked with oscilloscope = ok.
MCU makes reset if the fuel level sensor is connected ??? (and blinks warning lights)
Any idea what causes problem ?
I think that something is corrupted in the MCU´s memory so the next question is:
Is it possiple to upload new software in to MCU ?
MB VITO 110cdi year 2002
Thanks for any help...
Old Jan 18, 2005 | 04:45 AM
sleepwalker's Avatar
Default RE: Vito´s instrument cluster broken ?
75 ohm means that you got a little more than 1/2 of fuel in the tank.... that's correct.
sounds like the instrument cluster problem to me.
try parameterizing it first. you can use HHT or Star Diagnosis
jerzstyle00
Apr 22, 2011 10:05 PM
fcalero
Jun 30, 2006 03:13 AM
danj111
Oct 16, 2005 01:16 PM
CLK500KID
Oct 29, 2004 12:24 AM
