Vibration, loss of power, steering
Hello guyz,
Well i have a 94 model, C36 AMG & it has been through lot of repairs.[:'(]
First when i go above 80 kms the steering starts to shake,
second when i am accelerating the middle of my dashboard where the ac controls are fixed vibrate for a moment.
third, how can you decrease tire noises.
fourth, sometimes it take a few seconds to accelerate... feel loss of power.
NOW TO SOLVE SOME OF THESE PROBLEMS I HAVE DONE THE FOLLOWING:
i HAVE REPAIRED THE BUSHINGS, THE FRONT SHOCK ABORBERS AS WELL AS BALL BEARINGS FOR STEERING BUT STILL THE STEERING VIBRATES TOO MUCH
RECENTLY MY WIRES OF THE ENGINE COMPARTMENT BURNED (yes they did & they burnt the computer< the airflow sensor & the relay)[:@]
I HAD TO CHANGE ALL THIS.
NOW I HAVE ONE MORE PART TO CHANGE & THAT IS THE IDLE VALVE CONTROLLER.... THE RPM OF THE CAR ARE NOT STABLE WHEN I PUT THE CAR INTO THE GEAR IT COMES UP & DOWN SOMETIMES GOING UNDER 500 RPMS WHICH MAKES THE CAR SHAKE & SOMETIMES SWITCH OFF.
I will be really glad to hear some of the experiances you had with this CURSED MERCEDES C-CLASS....
Regards,
Regards,
RE: Vibration, loss of power, steering
you replaced ball joints, tie rods, center drag link and steering damper? Im assuming you did a complete tune up on the engine (spark plugs, wires..fuel filter..etc). That pretty much sucks that this car is doing evil to you. Good luck with it...or better yet sell it and get an e500 (older model) Its a way better car.
j-mang
j-mang
TX98C280
06-17-2007 01:39 AM
