vclass transmision problems
Old Jun 7, 2007 | 03:34 PM
chris07's Avatar
Default vclass transmision problems
just thought i would let everyone know about possible causes to faults on zf auto box my v230 as been playing up for about a month the gearbox light would come on and the car would go into get home mode this started to get worse and the gearbox would only select 1st gear and reverse othertimes it would be in 3rd gear so i took it to merc comercial dealer who did a diagnostic on it the only fault they could find was code 224 which is the internal speed sensor merc cant fix this there solution is to put a new gearbox in after phoning around i found a automatic transmision specialist they can fix this fault without removing the box from the car at under half the price it would cost to fit a new box so if your having any problems with your box doing the same things as mine this could be the problem its quite common they burn out with the heat dont go to merc go to auto gearbox specialist they can put a special fluid in it to stop it overheating so you wont get the problems agian
hope this helps someone
chris07
just thought i would add somemore info beside the gearbox fault there was also a fault on the throttle body this can also do the same things as said fault on gearbox so get this checked out first if its only this whats at fault it could save you a lot of money in my case i had both faults present so its cost me a fortune to get fixed good job i got the car cheap
chris07
Old Jun 8, 2007 | 12:04 AM
BlueSilver's Avatar
Default RE: vclass transmision problems
Will you post a pic of your V-class. My wife wants one, but are not for sale in the country. We are checking into importing one.
Blue
Old Jun 9, 2007 | 02:55 PM
chris07's Avatar
hope this will give you nan idea its the only one ive got car away having gearbox repaired
chris07
[IMG]local://upfiles/22393/23F4387E24E145309D47A64D7840EEFC.jpg[/IMG]
Old Dec 9, 2013 | 10:29 AM
Leonax's Avatar
Hi
I have a V220 year 1999 and the transmission its not engaging.Warn light is on.Does someone no how can I fix that.I heard with lucas anti slipping fluid can do?
Rg
Noel
juanpablo
Dec 30, 2007 01:27 AM
took
Dec 29, 2006 07:25 AM
zafar320
Jul 8, 2005 05:01 PM
kev2
May 23, 2005 12:20 AM
CCCP
Feb 18, 2005 05:10 PM
