Vacuum/fuel problem? - need help
Old Sep 6, 2006 | 02:19 PM
khines819's Avatar
Default Vacuum/fuel problem? - need help
I have an '86 420 SEL, 200K miles.
Started fine, and kept stalling when I put it into gear. So I started it, and took a look around. There is an air leak sound coming from behind the rear passenger tire (near the fuel filter). Sounds like I have a hole in the tire - best way to describe it, but no it is not the tire. Couldn't find the leak though.
After a few minutes of looking around, I put it into gear and it ran fine for over an hour drive. I parked it, left it overnight, and can't get it started.
I just got the car a month ago - know very little about Mercedes fuel and vacuum system, but I don't want to tow it to a mechanic if there is just a hose somewhere that dry-rotted.
Anybody have any ideas of what this might be?
The AC went out too just recently - don't know if this has anything to do with it, but I figured it it might if there is a vacuum problem.
Old Sep 6, 2006 | 05:43 PM
snanceki's Avatar
Default RE: Vacuum/fuel problem? - need help
Don't have any experience on MB's this old. However I think you have found the problem UNLESS the noise you hear is just the electric fuel pump running.
It appears that the line used to connect the tank to the underbonnet charcoal can may be leaking. Assuming that your car has a charcoal can for fume purge.
Such a leak is likely to give symptoms like those you describe.
Need to get the car on a ramp and trace all lines from tank to engine bay. The problem one will be the line which is NOT carrying fuel to the engine but you should be able to determine this by following the noise.
Good luck.
Stuart
Xacting
Feb 12, 2007 09:42 PM
hossconcentric
Jun 5, 2006 10:39 PM
grandwazoo
Apr 19, 2006 02:16 PM
Walter Marria
Oct 2, 2005 09:25 PM
chaz13
May 10, 2004 12:57 PM
