Timing chain question
Old Apr 16, 2008 | 04:41 PM
gustafsonerik's Avatar
Default Timing chain question
i have a 83 380sl and i have a 82 380sel engine..i'm going to swap them out.. Can you tell me where and what i have to upgrade with the timing chain?? and where do i get the parts thanks Erik
Old Apr 16, 2008 | 05:37 PM
idcelr8's Avatar
Default RE: Timing chain question
The only way to tell if the single chain has been replaced with the double is to pull a valve cover and look at them. If you see two sprocket wheels on the end of the cam and the chain is twice as wide as a single chain then the conversion has been done.
The early cars (1980 in Euro, 1981 in the US) had the single chain. I do not know when Mercedes went back to the double chain they has used in the past but they did as the warrenty cost was eating them up. They would not retrofit your car for free (it cost about $2200 at the dealer) but they would replace your engine if it snapped during the warrenty period.
Most of the 3.8 engines have been converted by now or they would not have lasted; something to do with US driving habits as I understand. Still, checking is as easy as pulling a valve cover and looking.
This is not a conversion for the beginner. You might check with some independent shops that have been around for a few years and see what they would charge. Parts for this are easy to get and they will know where to get them.
Another option (if you find yours is a single chain) is to shop around until you find one that has been converted and then sell the engine you have. They should not be hard to find if you just check with a few wrecking yards.
Sam
Old Apr 16, 2008 | 07:23 PM
okay what will i need a double chain,two camshaft sprockets and a crankshaft sprocket??? anything else???
Old Jan 4, 2011 | 11:00 AM
Brok Data's Avatar
Smile 380SL timing chain thoughts
I still have the single chain on my '81 380. My mechanic in Edmonton, Canada charges me $300.00 to replace the chain and the tensioner. It seems that if the tensioner wears out it allows the chain to wobble and eventually fail. If you keep up with maintenance there will never be a problem. To be safe I just replace them every once in a while. A dual retrofit is $3,000.00 installed. At that rate I can replace my chain and tensioner every 2 years for a long time and still come out ahead. Just offering another opinion on a hotly contested topic!
Junger
Mar 20, 2013 05:38 PM
Slkboi2000
Sep 5, 2006 07:01 AM
PANSSER
Dec 27, 2004 01:26 AM
Mwagon
Jun 4, 2004 10:33 PM
T Lindau
Dec 29, 2003 03:10 PM
