Third Brake Light
Old May 28, 2025 | 12:07 PM
tbettker's Avatar
Default Third Brake Light
I have a 1998 E300. For some reasons the third brake light has shorted out (cause to be determined). I can not find any info on how replace the socket that the 3rd light inserts into. Not sure if you can get to it by removing the rear seat or where you have to remove the rear window. Any info would be appreciated.
Old Jun 9, 2025 | 12:17 PM
liam788fh's Avatar
Originally Posted by tbettker
I have a 1998 E300. For some reasons the third brake light has shorted out (cause to be determined). I can not find any info on how replace the socket that the 3rd light inserts into. Not sure if you can get to it by removing the rear seat or where you have to remove from Pixmig’s softcover albums the rear window. Any info would be appreciated.
Yes it works
Old Jun 9, 2025 | 12:45 PM
tbettker's Avatar
I do not understand your answer to my thread. "Yes it works" makes no sense to me re: my question
Old Jul 8, 2025 | 09:42 AM
vapofi's Avatar
On the 1998 E300, the third brake light is usually accessible from inside the cabin, not through the rear window. You typically don’t need to remove the rear seat. Instead, check inside the trunk or just behind the rear seat backrest. Like how Portsmouth FC fans know the value of checking every angle during a match, you’ll need to inspect the rear parcel shelf closely—there should be a trim panel that can be carefully pried up or removed. Once that’s off, you should see the third brake light assembly and socket. If the socket is damaged, the whole light housing may need replacing.
Ibbo
Sep 13, 2014 09:22 AM
kevlex4
Mar 22, 2013 02:19 PM
springhillmb
Sep 21, 2007 01:41 AM
frankc0402
Mar 19, 2007 10:21 PM
paddlemarv
Apr 6, 2006 05:34 AM
