Sun roof and cruise control problem
Hey guys, I am having some trouble with my 1998 CLK 200 and I though that you might be able to help me:
First of all, my sun roof has stopped working. It opens fully fine, but does not shut electronically (switch doesn't do anything). I've checked the fuses but there doesn't appear to be one dedicated to the sun roof. Any ideas?
Secondly, my cruise control stick is loose and doesn't do anything. It feels like it has become detached from the switch. I had a look at pulling away the steering column cover but this appears to require the removal of an awful lot of dash. Is this correct and is this a common problem? If so, is it relatively easy to fix?
Again, you help would be much appreciated!
Paul
Paul
RE: Sun roof and cruise control problem
before renwewing the sr sunroof switch try andreset it by closin it on1st click,when 1st click opreted its gonna stop so carry on till it reaches to close position and hold it for six secondsfor it to rest,after rest open fully,when closing you either hold it on 1st click or second click it should work with out stopping,the cause for this is sr not opreted regulary.let me no hw u get on thanx..........
vanillaice123
10-25-2009 04:57 PM
