Starting problem
Old Aug 20, 2005 | 04:49 PM
TBenedikt's Avatar
Default Starting problem
My 1984 Mercedeses 380SL has a strange problem, at times it does not want to start and when it does the RPM will fluctuates between 1500 & 600 RPM this goes on for 15 or 20 seconds and then it settles down to its normal idle. The engine will also stall at times right after driving for a short distance and then slowing down or stopping at a light. It does not seem to matter if the engine is cold or warm. I have put in new plug wires as well as distributor cap & rotor. The fuel pump relay is also new. I would sure appreciate it if someone coluld shed some light on this problem and direct me as to what should be done to remedy it. Thank you.
Old Sep 12, 2005 | 03:02 PM
rayhalks's Avatar
Default RE: Starting problem
I have the same problem with my 89 300E.
What did you find to be the problem?
duncan
Mar 9, 2009 05:47 PM
stingray380sl
Nov 4, 2004 10:23 PM
Expat_Ron
Apr 5, 2004 05:49 PM
Billmer
Jan 24, 2004 09:01 PM
marbry
Jan 20, 2004 04:15 PM
