Speedo works, odometer doesn't
Old Jan 8, 2006 | 12:12 AM
Popsicle's Avatar
Default Speedo works, odometer doesn't
So I acquired an '89 300E last month. Drivetrain is in good condition but many accessories were not working. That included the speedometer, cruise control, odometer, and trip odometer. No problem, really, considering the speedometer cable was broken.
I replaced the speedo cable and sure enough, the speedometer now works and so does cruise control. But the odometers still do not work. I can't find them mentioned in my manuals. Any idea what makes them work?
Old Jan 8, 2006 | 04:26 AM
sleepwalker's Avatar
Default RE: Speedo works, odometer doesn't
thats already an internal problem in the instrument cluster.
was the counter reset button not halfway pressed or something?
Old Jan 8, 2006 | 09:04 AM
Popsicle's Avatar
I will fumble around some more, but I suspect you are right. Internal problem, replacement is only cure. Thanks for replying.
Old May 16, 2006 | 05:12 PM
tygger's Avatar
Did you fix this yet? Where did you get the replacement and how much was it... if you don't mind. Thanks!
Old May 16, 2006 | 07:27 PM
Popsicle's Avatar
No, never fixed. I have had other more pressing things to do.
Old May 17, 2006 | 08:11 AM
Shan's Avatar
No need to replace the whole speedo if you are adventurous enough
and a little mechanically inclined.
Remaove the speedo from the instrument cluster and the back cover.
When you have access to the wheels of the odometer, you will see one unnumbere wheel (may be greyish).
It should not turn freely on the axle. If it does that is your problem.
Use a drop or two of ARALDITE or similar hard setting epoxy glue to stick to the axle
(the small rod on which all the wheels of the odo rotate).
Once the glue sets properly, test the wheel to make sure it does not turn freely anymore.
Fix everything back.
SHAN.
Old May 17, 2006 | 09:18 AM
Popsicle's Avatar
Amazing! It just goes to show that if you ignore a problem long enough, someone comes along to give you a cheap solution. Thanks, Shan.
Snyder03cobra
Sep 30, 2014 09:29 AM
hughits
May 19, 2008 12:26 PM
fastboy143
Nov 21, 2005 08:41 PM
samahmed2002
Sep 16, 2005 01:02 AM
rikblacketer
Jan 15, 2004 10:18 PM
