soft top / roll bar inop after battery replaced
Old Aug 13, 2007 | 08:36 AM
rc16001's Avatar
Default soft top / roll bar inop after battery replaced
After replacing battery (1997 Mercedes SL 600)soft top and roll bar will not work, both switches lights stay on can anyone help
Old Aug 13, 2007 | 04:19 PM
AMGMercedes's Avatar
Default RE: soft top / roll bar inop after battery replaced
My guess is that a fuse was blown or needs reset?
Old Aug 13, 2007 | 05:40 PM
NAZ's Avatar
NAZ
requres reset by MB STAR DIAGNOSTIC,OR A VERY CLEAVER SCANNER,WAT IT DOES IT NEEDS TO BE READ AND ERASE FAULT MEMORY........
Old Aug 14, 2007 | 07:26 PM
MBTECHINFO's Avatar
If you have the soft top service wrench you can manually operate the top (see owners manual) into the closed/locked position and try it and if not working, move it into the open/locked position, make sure that the latches all look identical when you look down into them so that one is not released and the other side latched. Comonly this cycle will remedy a simple complaint and a visit to the dealer can be avoided. This process is easier said then done for a novice.
paddlemarv
Jun 6, 2007 10:41 PM
patrick christian
Oct 26, 2006 04:26 AM
davewrit
Oct 16, 2006 01:20 AM
V XII
Jun 9, 2006 09:24 PM
sonysmith
Feb 17, 2005 10:06 PM
