SLK 320 Trunk will not open
Old Apr 15, 2010 | 10:38 PM
fsears's Avatar
Default SLK 320 Trunk will not open
My wife has a 2001 SLK 320, the trunk will not open with the latch. I can hear the lock engaging/disengaging and the handle feels like it either is locked or moves about half way when you try to open it. At first the handle felt like it was locked, after locking and unlocking it several times the handle would move about half way when you tried to open it. Thanks
Old Apr 19, 2010 | 07:51 PM
bearsbusa's Avatar
I have seen the rod fall off of the latch assembly or also the handle. Lucky for you it is a SLK. Open the top enough so the deck lid opens. You will be able to access the handle and latch this way. Good luck!
Old Apr 20, 2010 | 01:10 PM
fsears's Avatar
Thanks for the reply, only problem is the guard is not pulled back so opening the top is not an option.
Old Apr 20, 2010 | 01:47 PM
BeshoffGal's Avatar
If you call Roadside assistance within MBZ 1-800-367-6372, tell them that you locked your keys in the car and they will come out to your home to unlock/break into the trunk to have it opened. As far as parts are concerned... your going to need a new rear lid lock mechanism. Which goes for about..$246.00 for the parts. Check out my website.
dee2000
Jul 21, 2011 07:43 PM
cathyv751
Mar 7, 2011 05:14 PM
rayc320
Jul 9, 2010 05:49 PM
fastfed
Apr 10, 2009 01:18 AM
dgrover
Sep 3, 2008 08:47 AM
