SLK 230 front brake pads
Old Jan 26, 2008 | 07:38 PM
mfarr's Avatar
Default SLK 230 front brake pads
I need to replace the front brake pads on my wife's 1998SLK 230, and I have3 and 1/2 questions.
1)Where can I get a repair manual? Auto parts stores don't carry them, and the dealercharges a fortunefor access to their repair manual.
2) What is the minimum allowable thickness for the front rotors?If Ileave rotors with less than the minimum thickness on, is it really a safety issue or just a performance/wear and tear issue?
3) Replacing the pads looks pretty straight foward, similar to american and japanese cars I've worked on before.Is there any special trick or suprises I should know about?
Old Jan 26, 2008 | 07:45 PM
chassis221's Avatar
Default RE: SLK 230 front brake pads
the thickness is stamped on the rotor. sometimes hard to see but it is there if it is a MB rotor. will have part # then spec in mm'syes the brake job is straight forward. if you dont see a huge lip around the edge of the rotor you prob ok then. the worst that usually will happen is brake squeel or vibration when braking.
Old Jan 26, 2008 | 08:04 PM
Black04C230's Avatar
Check Ebay for the repair manual. Way cheaper than the dealer.
Old Jan 26, 2008 | 08:10 PM
mfarr's Avatar
Thanks for the info. Actually there is amoderate lip around the edge of the rotor, probably a little more than 1/32 inch, definitely less than 1/16 of an inch. I'm fairly sure the front pads were replaced once before by the previous owner. One more question--do the OE pads from mercedes contain asbestos?
Thanks!
Old Jan 26, 2008 | 08:13 PM
chassis221's Avatar
not sure on that, but im sure that they probably do.
greenl
Mar 15, 2012 05:19 PM
Sira143
Dec 14, 2006 02:30 AM
MAT3867
Jun 2, 2006 12:25 PM
oleg_8831
May 27, 2006 03:53 PM
C280 wizard
Oct 10, 2004 06:16 AM
