slk "Low Coolant" light coming on
Old Apr 18, 2008 | 12:52 PM
rickyhenry's Avatar
Default slk "Low Coolant" light coming on
hi,
last week the low coolant indicator light on the dash came on. I quickly went and picked up a 50/50 mixture to refill the coolant. When the car was cooled down, i opened up the fill cap and began to fill. I put in only about 4 oz of coolant. The light continues to periodically come on then turn itself back off, then on again. the car is not running hot and the coolant level is not low. I don't see any leakage and i didn't even fill it up as there was plenty of coolant in there. considering i put in only 4 oz of coolant and the car holds 4 qts, what could be going on with the car?
Old Apr 18, 2008 | 12:53 PM
rickyhenry's Avatar
Default RE: slk "Low Coolant" light coming on
Oops, forgot to put what type of car. the car is a 230 SLK, 4 cyl super charged. Thanks!
Old Apr 19, 2008 | 02:31 AM
snanceki's Avatar
If fluid level is correct then next suspect is the sensor in the tank.
Stuart
Old May 7, 2009 | 11:05 AM
Rudeldu's Avatar
Default Level Sensor changed - no change
I have a E-Class 1999 model and experience the same indications. The light still comes on, even after I put in a new level sensor. I recognized the light only comes on in combintion with the AC beeing on and the coolant temperature above 70deg. The light, once on will not go out when I turn off the AC. Has anyone run across the same problem and was able to fix it? If so, I am very thankfull for your help.
vr
Rudeldu
benzdude2
May 7, 2012 04:31 PM
Kerwin Leader
Dec 3, 2011 11:46 AM
JERSEYSURFER
Oct 2, 2008 01:03 PM
TheBenzMan
Mar 5, 2008 04:25 PM
vlcak
Jan 8, 2007 03:07 PM
