SLEEPWALKER HELP
Old Feb 13, 2007 | 07:20 PM
mythreesons's Avatar
Default SLEEPWALKER HELP
trying to change pads on 93 300E. Any tricks on loosening the bolts that hold the calipers on? Sprayed CRC thinking about using breaker bar but, wanted to check with you first to see if they could be threaded differently
Old Feb 13, 2007 | 07:52 PM
sleepwalker's Avatar
Default RE: SLEEPWALKER HELP
it's a normal thread pattern.
crc cannot penetrate inside. try wd-40
Old Feb 13, 2007 | 11:08 PM
wmercer's Avatar
For my 93 MB, the calipers stay bolted on and just pins slide out to replace pads. Sorry to hear you have to remove calipers.
bill
Old Feb 14, 2007 | 12:45 PM
Thanks for the info. Have not taken the calipers off yet will look to see if it can be done without removal. Had to do it on other vehicles, just figured I needed to do the same
Old Feb 14, 2007 | 02:18 PM
mbz300sdl's Avatar
Yeah on my 300sdl and 560sel u just remove the pins. But dont feel bad the first time i did the brakes on my 300 i did the same thing.
Dehaven
Dec 21, 2005 12:25 AM
SANDDOG
Sep 3, 2005 06:40 PM
Shan
Aug 31, 2005 07:18 AM
hjtw
Jun 3, 2005 10:28 AM
Mawbs
Jun 2, 2005 08:07 AM
