Setting Idle on a 560SEL
How do i set the idle on my 560sel i took it to the dealer awhile back and they set the idle up to high and i dont plan on paying someone to set the idle on my car. I normally do my own work so if it is harder to do plz still explain.
from the small hole in the middle of the air cleaner, insert a long 4mm allen key.
if air cleaner is removed, just behind the sensor plate of throtte body (front of fuel distributor).
clockwise, higher rpm.
This is the first in a series that is a pretty good guide to how the idle system on 420/560 KE jetronic idle system works.
Mercedes 560SEL MY 86/91 Idle Speed Adjustment Tutorial Part 1 - adjusting ISCV high idle when warm - YouTube
