serp belt how to?
Old 07-14-2007 | 01:23 PM
brian576's Avatar
Default serp belt how to?
i had a different question posted earlier, but I've found out the main issue, please read the third post in the thread....thanks for any help anyone is able to give me in the next 24 or so hours!
1987 300 E with abouth 230K miles on it
Old 07-14-2007 | 07:23 PM
The Big Dog!'s Avatar
Default RE: engine issue....
This may be totally unrelated!
When all those things happened to me in my old Toyota Corolla, it turned out to be a bad alternator. The battery was being sucked dead which caused the computer to start shutting down everything. Again, could be a coincidence too.
1989 300E with 75,000 milesjust south of you in Elk Grove, Ca.
Old 07-14-2007 | 07:48 PM
brian576's Avatar
i forgot to mention this...so i popped the hood and found what pretty much amounts to as a shredded serp. belt...which is very convient for a guy who doesn't know how to replace it and it's a saturday where no repair shops of any reputation are open (I made several phone calls)...does anyone happen to know the exact steps required to get a new serp. belt onto my car? take me from opening the hood to closing the hood if you can - what all do I need to remove, etc.
Old 07-15-2007 | 04:51 PM
BlueSilver's Avatar
Since you have to replace the aux fan anyway, It would be easier to remove the four bolts in the top radiator brace, then lean the radiator forward some where you can work on it, and replace the belt too. There is a tensioner adjustment, for tighterning the belt; use a ratchet to tighten the new belt snug. I think the path of the belt is in your owners manual. Either way, you can tell which way the belt goes around the pully, by the type of pulley.
blue
Old 07-16-2007 | 02:18 PM
brian576's Avatar
thanks for the help, I'm glad I didn't have the cojones to do it myself though...needs a couple of pullies, springs and tentioner replaced...the shop is doing it today for me, which i hate cause I didn't want to spend so much on this ancient vehicle
how long should it take a good shop to make a repair like this?
PelicanParts.com
06-25-2013 12:45 PM
rogerc
08-30-2011 05:40 PM
PortalanzaMD
05-17-2010 02:54 PM
Paul
12-30-2003 06:59 PM
zjacomb
12-15-2003 07:14 AM
