S430 Fuse Box Location
Old May 18, 2006 | 10:14 PM
pokerpup's Avatar
Default S430 Fuse Box Location
Found one in engine compartment on right side near firewall, and one on left near firewall, and one under the back seat. Supposedly there is one in the right front engine compartment with 5 fuses and three relays in it that contains the fuse for the horn. My horn is not working and would like to check this- any ideas?
Old May 19, 2006 | 12:47 AM
sleepwalker's Avatar
Default RE: S430 Fuse Box Location
126, 140, or 220?
Old May 19, 2006 | 02:29 PM
pokerpup's Avatar
It's 220
Old May 19, 2006 | 09:25 PM
if after 2002, you got another set of fuses on the cockpit.
open the right door and on the side of the dashboard... there is a covering on it. (the one facing the door).
just pry it out.
[IMG]local://upfiles/1/76CFB421065E4BA5ADE66CAB7DC424D1.jpg[/IMG]
Old May 20, 2006 | 12:08 AM
pokerpup's Avatar
So sorry- should have told you it's a 2000. Should have told you that! We popped the cover off the horn relay today ( located inside the right engine compartment fuse box) and when the contacts are manually pressed together the horn works.
Old May 20, 2006 | 12:24 AM
pokerpup's Avatar
One more question- getting a message that rear fog lamp is out- where is the rear fog lamp?
Old May 20, 2006 | 07:19 AM
left side
Nytrydr
Jun 4, 2014 10:08 AM
Mr.745
Dec 31, 2011 10:40 PM
tomfer114
Oct 19, 2010 07:26 AM
Wisjd
Feb 1, 2009 12:13 PM
bcvanbelle
Mar 21, 2005 11:23 PM
