reverse only
Old Oct 10, 2007 | 09:26 PM
boomerfix's Avatar
Default reverse only
have a 722.6 tranny will only move in reverse. all forward gears not working. any ideas? thanks for any help i can get!!!!!!!!
Old Oct 10, 2007 | 09:47 PM
chassis221's Avatar
Default RE: reverse only
does it tell you what gear your in on the cluster, when your in drive does it say D or nothing? what model and year car?
Old Oct 10, 2007 | 10:41 PM
nedim's Avatar
Maybe its in limp mode. It happens when you have problem with transmission. Is your check engine light on? How many miles do you have on? just few more info would be great.I have same trany inmy car its dying...
Old Oct 11, 2007 | 07:05 PM
boomerfix's Avatar
170,000 mi on 95 s320
Old Oct 15, 2007 | 09:06 PM
boomerfix's Avatar
it sounds like the engine is pulled down when switched into gear but doesnt move in 1st 2nd 3rd 4th or drive. reverse goes right in. noticable difference when switched fromneutral into gear but no movement. doesnt have a cluster per chassis and no check engine light
Old Oct 16, 2007 | 07:23 PM
boomerfix's Avatar
any tranny experts out there??
Old Nov 18, 2007 | 06:46 PM
boomerfix's Avatar
took off pan (blackish fluid) took off valve body looks ok valves are free should i be looking at clutches disks solinoids? or whole tranny? any help? so far this site is coming up useless
Old Nov 19, 2007 | 02:54 PM
boomerfix's Avatar
no checkk engine light or obd codes
Mrman
May 10, 2015 08:16 PM
pred8tr
Feb 10, 2010 08:11 PM
87 560SL RR
Jul 10, 2007 06:25 AM
76benz
Aug 31, 2005 12:06 PM
KarlXll
Sep 8, 2003 08:43 PM
