Remove the engine 300td
Old Jul 7, 2011 | 07:50 PM
DIESELGUS's Avatar
Default Remove the engine 300td
Due to compression bypassing the piston rings it is time to rebuild the engine in my 83 TD w/500K.
To those who have don it;
What is the best and easiest way to remove the engine – with or without the transmission?
Also, is there any literature on this engine removal procedure?
Thank y’all in advance,
Gus
Old Jul 9, 2011 | 10:37 AM
DIESELGUS's Avatar
ForcedInduction;
Thanks for your recommendation.
Should the radiator and other engine accessories (fan, water pump, AC conp, etc) on the front of the engine be removed to make removal easier?
I will be doing this job alone.
Any help full hints will be very much appreciated.
I thought more members would have commented on this issue.
Best regards,
Gus
Old Jul 11, 2011 | 09:21 AM
DIESELGUS's Avatar
Thank you in advance;
Gus
car5car
Aug 22, 2011 09:17 PM
UKMercNut
Dec 17, 2008 12:24 PM
will3hawks
Jan 25, 2008 12:50 PM
spinkb
Mar 16, 2006 04:30 PM
roveroverxd
Jan 28, 2006 09:47 PM
