rear axle assembly 1960 220Sb
Old Jul 7, 2013 | 04:31 PM
TheOuthouseMouse's Avatar
Default rear axle assembly 1960 220Sb
I am attempting to reassemble the rear axle on my 1960 220Sb. However, when I took it apart, I forgot to take pictures, so I can't remember how to put this shaft, washers, and rubber bits. I am attaching a picture to show the parts about which I am talking. Also, I am attaching a photo out of the parts manual that is an exploded diagram of these parts. It's unclear to me how to (or in what order) to reassemble these parts.
Also, in the picture entitled IMG_1696, there are two old parts from the rear axle (I don't know what they're called). I replaced them with the shiny new part you can see in the middle of the picture entitled IMG_1697. The problem is that the new part is slightly longer and and, thus, the little nut on the left in IMG_1696 doesn't fit. This complicates out to reassemble the shaft with the washers and rubber bits in the previous photos. So, I am at a loss here as to how to proceed.
Any help would be appreciated.
justin l.
Attached Thumbnails rear axle assembly 1960 220Sb-img_1693.jpg   rear axle assembly 1960 220Sb-img_1694.jpg   rear axle assembly 1960 220Sb-img_1695.jpg   rear axle assembly 1960 220Sb-img_1696.jpg   rear axle assembly 1960 220Sb-img_1697.jpg
TheOuthouseMouse
Jun 6, 2013 07:09 AM
TheOuthouseMouse
May 27, 2013 10:52 AM
TheOuthouseMouse
Feb 12, 2012 08:58 AM
AJ
Sep 21, 2005 02:32 PM
stephen
Mar 15, 2004 08:01 PM
