P-107 code
Old Dec 18, 2012 | 02:09 PM
500hp406's Avatar
Default P-107 code
I have just been giving a 1999 230 kompressor. The car is like new and after driving it for about 6 months the check engine light came on. I checked it with my obdII and got a p 107 code. After some checking most think it is the MAF. After clearing the code I proceeded to see what would cause the light to come on. If I run the RPM over 4000 the engine sounds like it is hitting the rev limiter. and the light comes on after a short time. If I clear the light, and drive it under 3000 rpm, the car will go for about 250 miles and the light will just come on. I pulled the MAF and cleaned it with carb cleaner, but did not seem to make any difference.
Before spending the money on a new MAF, then finding out it was something else I though I would try the forums for some possible expert advice. Anyone out there have a similar experience and what fixed the problem.
Thanks in advance....
Old Jan 10, 2013 | 08:17 PM
mb1088407's Avatar
Was there oil on the hmaf element?.. when u removed the hmaf was there oil in your charge pipes?
suncat
Mar 5, 2005 06:39 PM
rememberjeff
Aug 19, 2004 06:13 PM
convertguy
Apr 16, 2004 10:26 PM
nydan
Apr 12, 2004 04:10 PM
convertguy
Mar 26, 2004 07:05 PM
